-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Wrong way battery? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/976426-wrong-way-battery.html)
Keith V. 11-03-2017 04:08 PM
Wrong way battery?
Hello All. I know this is a dumb question, but should the battery be negative or positive terminal to the front of the car? Stop laughing! I am putting the battery back in after some time, and having a heck of a time with the battery hold down clamp. No matter how I position it and screw in the bolt, it is not holding the base of the battery securely. Thank you for your reply.
76-914 11-03-2017 05:00 PM
Neg towards the front.
Keith V. 11-04-2017 06:40 AM
Thank you, 76-914. And one more question, which direction should the wedge like battery hold down piece be facing? The wide edge with the lip facing downward or upward? I imagine anyway that works is fine, but I would like to have it “Correct”.
Tobra 11-06-2017 10:53 AM
What kind of battery? I had to cut off some little nubs on the bottom of my red top
