Jim Smolka's Avatar
Aftermarket FI
Ideally, as technology improves, so does performance.
I have a stock FI 2.0. Is there an aftermarker ECU that meets the following requirements :
1. Uses the stock componets and wires
2. Has an O2 sensor input.
3. Replaces the manifold pressure monitor with an air mass meter. (optional)
4. Improves performane
If not, what aftermarket FI systems are available for the 914. I am especialy interested in one that can accept an O2 sensor input.
Smoke Daddy
Old 09-16-1999, 07:43 PM
Accel, SDS, Electomotive, these are the ones I've been told about.
www.SDSEFI.com
www.ELECTOMOTIVE.com
www.mrgasket.com
Good luck
Old 09-17-1999, 09:33 AM
I spelled electromotive wrong
www.electromotive.com
Old 09-17-1999, 09:35 AM
Wrong address
http://www.emi.cc/home.htm
Old 09-17-1999, 09:37 AM
There is only one aftermarket FI kit for the 914. http://cbperformance.com/
all the others are a DIY generic type.
Old 09-17-1999, 09:45 AM
You can also try these companies (I have no experience with them or their products):
http://www.fuelparts.com
http://www.sdsefi.com/index.html
Alpine
Old 09-17-1999, 07:54 PM
