rack spacers again
Searched thru the archives looking for aftermarket rack spacer dimensions and longer bolt size but couldn't find it. Anyone have one they can measure easily, or closely approximate. Stock bolts measure M10-1.5 x 35mm (assume metric class 10.9, comparable to US grade 8) , so I'd guess that for a 1/2" spacer you'd need 45 or 50mm bolts.
Thanks Ed
'74 914 V8 '70 914 |
Try this one - 15mm
Bump steering spacer dimensions? |
I purchased the kit from pelican; very nice hardware and cool anodised spacers. Bolted in perfectly and solved my bump steer problem.
