Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
Injector cleaning voltage
Hey guys,
New to this forum with a 914. I have a 71 914 1.7L that I want ready for this summer.
I have removed my injectors to clean them. I am pretty sure they are clogged and need a good cleaning. Got new seals to replace as well since I have them out. Getting good gas pressure to them but no gas to plugs.
I don't want to burn them up so what voltage should I use to activate the injectors when spraying my cleaner. I have heard 12v is to much for these.
Thanks in advance.
Jason (aka surfdogskier)
Old 12-26-2017, 09:28 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Are you cycling them or just leaving them open? I think they can probably handle more voltage if you cycle them.
Your question is likely answered in Brad Anders' D-jet Bible.
It appears that the voltage across the injectors when they are being held open is about 4 to 5 V. So you should be fine providing that. Note that it might take more to open them initially.
--DD
Old 12-26-2017, 11:33 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Thanks for the response. I was just going to cycle them. I read somewhere that a lower voltage was better. Just wanted to run it by you guys. Didn't want to over do it. I don't know for sure if they are clogged but a good cleaning was definitely needed. Been sitting for a while. Figured I would start there.
Thanks again!
1970 Toyota FJ40 Landcrusier
1999 Lamborghini Diablo (build)
Old 12-26-2017, 01:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
