TURBO!!!
Ok y'all wanted turbo kits. . .
http://www.cbperformance.com/
these guys seem to have a lead on it. As for my above post I was speaking from a turbo point of view. I could not comment on heat about supercharing because I do not run it. However thermodynamics demands that you shead LOTS of heat when compressing a gas. Go and touch an air compressor in action!!! So you would still have heat issues if you went supercharging.
I would try NO if you really want HP increases. It would be simple and with low volumes of NO injection you could get long high HP gains. I'd just run a water spray cooler triggered with the NO injector. . .
It seems like for this vehicle going to a six is a better option. Again this is JMHO. . .
Old 09-20-1999, 12:55 PM
