Mike Kunz's Avatar
Send a message via AIM to Mike Kunz
1.8 L-Jet FI Diagnosis?
Hey...am helping out with a friend's 74 1.8 L-Jet which he is having trouble with. Car starts but dies after a minute or two.
Is there a good only reference for troubleshooting L-jet system similar to what I have seen for D-Jet??
Thanks!
Mike
VOPO '74 2.0
Old 02-13-2003, 06:58 PM
woodman's Avatar
you can search that subject here on this bbs, or get some more technical data on shoptalk forums under 914, FI or Type 4. But the for the real deal check out www.914club.com/downloads or something like that. There youwill find the porsche and bosch manuals. I've been buying the bosch books on ebay and half.com for very few $.
The site appears to be down, or maybe the Knob Creek is separating my cranial hemispheres and I didn't type in the correct url...single batch bourbon is the kind!
'75 1.8 -->1911
Old 02-13-2003, 08:53 PM
mike mueller's Avatar
For starters, make sure the relay for the fuel pump/injectors is working.
With key turned on, remove the air cleaner and move the flapper inside the AFM, this should activate the relay mentioned above.
What this does is as soon as the motor turns over and the suction of the pistons opens the flapper, the injectors get juice (but they do not fire until the coil collapses) and the fuel pump turns on.
A major vacuum leak will cause the motor to die due to the flapper not recieving enough vacuum or movement from the incomming air not being suffeciant enough...
When I was trouble shooting my L-Jet, I plugged up ALL of the hoses so that I knew the only air going into the motor HAD to come past the AFM.....this includes the hoses going to the Oil filler.
Old 02-13-2003, 09:32 PM
eric_ciampa's Avatar
Send a message via AIM to eric_ciampa
I have had more than my share of problems with my L-jet system. Mike has it right with the fuel pump. can you describe what exactly what is happening. how long before it dies? Can you hear the fuel pump? is the cold start hooked up?
It could be a number of things but i would start with the fuel pump like mike said. check your fuel pressue and make sure you have a good 30 psi the whole time. that will be a good place to start... but what do i know...
beautiful 74 1.8L pain in the BUTT!
you can write me directly at CHAMP914@hotmail.com [just no signing me up for any junk mail ]
Old 02-13-2003, 09:59 PM
Search button works good on this one:
HELP with 1.8 FI
- Dave
Old 02-14-2003, 02:51 PM
Mike Kunz's Avatar
thanks, everyone...will relay this to my friend....kind of hard since we are doing this over the phone, but this helps a helluva lot!
Mike
VOPO '74 2.0
Old 02-16-2003, 07:21 AM
