924 944 gauge wiring difference?
Does anybody know the difference in pinout for the gauges from a 1979 924 and a 1983 944?
I am blessed/cursed with these cars: BMW 318iS 1991 BMW 325iS 1988 Volvo 740 Turbo Wagon 1992 Quote of the week: "This chemical is known to cause Birth Defects in California." Poor Californians, they are always getting the short end of it, and now this? |
I am not sure but if the guages are the same, then the wiring harness would probably be the same. I have never worked on a 944 but there should not be much difference in the guage wiring.
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
Mostly the same as the early 944's with the exception of the tach which does come off of the trigger side of the coil. No fuel consumption gauge thus no sensor in the back of the speedo either.
I have an old Clymer book. Thinking about cutting the back off of it and scanning it into a PDF file.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
