-   -   968 Cam and Crank sensor pinouts? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1001869-968-cam-crank-sensor-pinouts.html)
968gene 07-10-2018 03:59 AM
Anyone have the pinouts for the 968 cam and crank sensors?
Jfrahm 07-10-2018 05:09 AM
Timely question, I am rewiring my 968 hall sensor due to a crumbled connector. Real Soon Now. This thread covers the Hall pretty well and may have the right info for the crank sensor:
https://tinyurl.com/y7wbno4e
I am using a new cheap volvo crank sensor as a donor for the Hall connector and will splice it on.
968gene 07-10-2018 02:17 PM
Thanks for the reply. My trouble goes a bit deeper...it would be helpful to know which wire in the harness goes to ground. I think the middle is the signal, and the outer wires are ground and power.
Can you verify a ground signal? Can you verify a key on power signal?
Jfrahm 07-11-2018 05:45 AM
Mine is tape bombed until I get back in to rewire it, the connector fell apart while I was doing other work and I did not want to wait for a connector to arrive in order to get it back together.
This thread shows the pinout of the Hall, I think the other covers the CPS OK:
https://tinyurl.com/yadrax9e
Looks like red is pin #1 and black is pin #3, middle should be the signal.
968gene 07-11-2018 04:43 PM
ThankS
