late strut body attachment to early strut threaded cap - instructions?
any instructions out there on taking the threaded cap off of an early model year 944 strut and attaching it to a late model year strut?
87 944 NA
Old 07-30-2018, 05:43 AM
9FF 9FF is offline
9FF's Avatar
Is it so you can fit the early strut insert into a later strut? If that’s the case, it won’t work. The early struts are a smaller diameter so the early insert wil not fit tight into a late strut. You either have to use the Koni insert designed to be secured at the bottom instead of using any cap or you can weld on a different threaded cap designed for use with Bilstein inserts.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 07-30-2018, 06:51 AM
yes
but
apparently not
that's my dream - but - I can't find a guaranteed-to-fit sleeve - I had another thread going where some of these come up... but frankly, I'm lost.
87 944 NA
Old 07-30-2018, 08:22 AM
9FF 9FF is offline
9FF's Avatar
Originally Posted by Bukowski View Post
...that's my dream - but - I can't find a guaranteed-to-fit sleeve - I had another thread going where some of these come up... but frankly, I'm lost.
A company in Germany offered the sleeves and I'm sure I watched a yt video of them being fitted some years ago but quite honestly I'm out of the loop about whats still available now as I've moved onto MC coilovers on all but one of my cars.
What don't you like about the Koni inserts for the late cars?
I suppose if you are set on running Bilsteins there is always the Bilstein Escort Cup which is available in both street and track valving.
Mike A
Old 07-30-2018, 10:21 AM
what's the diameter of a late 944 shock tube "housing"? 50mm?
bet you could weld a 2" nominal pipe nipple and cap with a hole in it to retain the insert...
Old 07-30-2018, 11:03 AM
Misunderstood User
Use a pipe or strap wrench to take off.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 07-30-2018, 05:02 PM
