-   -   Broken speed/ref sensor connector (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1002734-broken-speed-ref-sensor-connector.html)
Derek C. 07-19-2018 10:38 AM
So I was poking around under the hood last night, and ran into a couple of electrical issues.
1. The wire that connects the turbo cooling pump had corroded through and was broken. It had been previously splicedand I re-spliced it, but the wire itself is very hard and had a previous splice. i am thinking I may have to dig this out of the harness and rewire it whenever I take the top of the engine apart.
2. A connector at the back of the engine crumbled. I believe it is a speed/ref sensor connector, and I believe it is the sensor side, not the harness side. Can anyone tell from the picture? If so, does anyone have a pigtail from a bad sensor they could send me, or should I just coat the thing with liquid electrical tape? I have enough work to do right now that I would rather not go after the sensors which work perfectly fine (but since i said that, they will probably die on me now).
http://forums.pelicanparts.com/uploa...1532021692.jpg
Derek C. 07-29-2018 12:20 PM
Bump - anyone know how to tell which sensor this is for? Chasing the wires is a bit of a mess back there. They had labels too. This one said DG, the other said BG. Cannot figure out what that means though.
Bradical 07-29-2018 01:48 PM
BG is your TDC / reference mark sensor (closest to the radiator) and DG is your speed sensor (closest to the firewall).
You can purchase new connectors for the DME harness from Lindsey Racing, but I agree- it looks like the damage is on the sensor side, in which case you can purchase a replacement sensor from our host, PelicanParts.
Some googling may reveal that a similar sensor used by BMW is less expensive and also available from our host.
Derek C. 07-29-2018 02:05 PM
Thanks! I'd rather not replace the sensor until it needs it, so I think I'll coat the entire thing in liquid electrical tape, and maybe cover that with some thick silicone or something while I look for a bad connector to steal the pigtail from. Of course I'm about to undertake a TB job and a clutch master replacement, so the "while I'm in there" stuff that creeps up over the course of those may make replacing it easy/timely.
Bradical 07-29-2018 02:25 PM
Well alright then. Incase you change your mind, you can grab a new one for $34.
Part #: 944-606-115-00-M85
Derek C. 07-30-2018 10:09 PM
Oof, the connnector completely fell apart when I removed it to try to salvage it. Anyone got a spare chewed up sensor they can sell me for a few bucks so I can harvest the pigtail? I have enough to do that I don't want to replace the thing if I don't have to.
kdjones2000 07-31-2018 05:25 AM
$34 bucks, Derek....
