Changed clutch now starts and dies
Hi i have a 84 944 auto it has had a clutch put in instead of the rubber flywheel. it was running fine until the rubber centre went in the clutch. the engine still fired up and ran as it should but the was obviously no drive.
I have now replaced the clutch and put everything back together but it will now only start for about 5 seconds then die. i have changed the speed and reference sensors and gapped them i have changed the DME relay and i have checked the AFM and the fuel presure all seem okay but it will not go! if i touch the throttle id dies instantly. please help! thank you |
In the Fires of Hell.....
Check the simple things first.
1) Did you reconnect your electrical connection to the throttle position switch? 2) Did you reconnect your plug for the AFM? 3) Do you have any vacuum lines not connected?
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
everything is plugged back in i have tripple checked
also if i unplug the TPS and the AFM it makes no difference the car does the exact same thing with both of those things plugged in or not |
everything is plugged back in i have tripple checked it.
if i unplug the TPS and the AFM it makes no diference the car does the same thing whether they are plugged in or not. |
