1990 s2 exterior lights are off on passenger side
Help! Any idea what’s going on?
​​​​​​​my passenger side side markers, tail light are not working. Driver side turns on but passenger side is off.
fuse 41 keeps blowing out. I took out both side markers and tail lights and made sure all terminals are connected and bulbs are good.
I only see 2 grounds - one at tail light and one in the front driver side. Both are cleaned.
Also, my driver side fog light is off and under hood light is off.
Old 08-04-2018, 04:35 PM
Look at the wiring and sockets for something causing the fuse to blow like a cracked socket or frayed wire insulation.
Old 08-05-2018, 04:30 AM
Thanks. Nothing so far. I cleaned all the light connectors for fog, signal and side marker lights. Wires look good.
There is no brake light when I step on the brake pedal. Passenger lights are still off.
Old 08-05-2018, 08:11 PM
Brake pedal switch?
Old 08-05-2018, 08:14 PM
When the brake pedal switch fail, does it affect tail light when I turn on the head light? My left tail light is on with parking light.
Old 08-05-2018, 09:40 PM
I'm not sure but you said no brake lights so I'd check that.
Old 08-05-2018, 10:02 PM
Could it be the head light switch?
All corners of the signal and tail light work with hazard light on
Tail light does light up under braking now
Old 08-09-2018, 09:30 PM
If the key is off and turn signal lever is engaged the parking lights on that side should light, too.
Old 08-10-2018, 02:54 AM
Check the loom as it runs across the spare tire well.
Old 08-10-2018, 01:30 PM
One parking light is not getting power. Using a circuit tracer, the harness appears to hv connectivity back to fuse box. Any idea why power is not going to that light?
Old 08-20-2018, 04:06 PM
