CV Bolts all sheared?!?
Just got this 1987 924s recently but a odd click from the right rear called for investigation. What I found was only one bolt remained, there was metal dust scattered and there was a mangled piece of metal on the remaining bolt.
Advice? What now?
Old 08-12-2018, 10:32 PM
Finish removing your cv joint and the old bolt stubs and see what you have. If the cv joint is undamaged, repack it with grease and reinstall it using new bolts.
Pay attention to use proper torque on the bolts, as this is probably what caused the old ones to fail. Prior owner either over-torqued and weakened them, or he left them too loose and the cv joint hammered the bolt heads off under load.
If the cv joint is damaged inside, you'll need to replace it.
Check the operation of that wheel bearing too, while you have it apart.
Old 08-13-2018, 12:50 AM
When you get it apart, see if both joints are indexed on the shaft
If you look at the ends, the fat part of the inner spider should be opposite the thin side on the other end.
Old 08-13-2018, 11:52 AM
Coeur d'Alene, Idaho
It happens when the bolts are not at the proper torque, or missing the lock washers. Too tight causes them to snap later. Too loose causes them to loosen enough for impact forces of movement to snap them one at a time. You caught it before the last one let go - good job.
No worries about the CV being damaged. It's way tough and this issue won't damage it. Just wipe out any dust/dirt on the end of the axle once you have it loose so you can swivel it to see that there is grease in it. Then get the broken stubs out and put on fresh correct bolts with the correct (Schnorr?) lock washers and you'll also want 3 new backing plates. They distribute the load like large washers and that piece of metal is the remains of one.
You dodged a bullet very well here. $40 worth of fasteners and you're back in business.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 08-14-2018, 05:30 PM
I forgot to mention in my earlier post, but if you find spalling ( metal pitting where the ball contacts the cage) inside of the ball cage in the cv joint, you can just swap sides with your axles.
The axles are the same length and can be interchanged L to R and R to L. Changing sides reverses the rotational direction of the axle and so it also changes the contact area of the ball and cage and gives the ball a fresh surface to press upon. I did this and it works fine.
Old 08-15-2018, 01:09 PM
9FF 9FF is offline
9FF's Avatar
Just an fyi, this only works on manual transmissions, auto trans have unequal L&R axles and the op didnít specify a trans.
Mike A
9TECHNIK | TRANSAXLE ńRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 08-15-2018, 02:54 PM
Yeah, thanks! I have a manual and never think in terms of automatics in a 944.
Old 08-15-2018, 07:15 PM
It also only works if you make the former inner end of the shaft be the OUTER end on the other side of the car. If you accidentally swing the axles around and cause the current inner end of the shaft (close to the transaxle), to be the inner end on the other side of the car you will accomplish absolutely nothing. Diagram this out to see why. Even experts make the mistake. I mark mine with a sharpie and be sure to orient them correctly.
Hope I got that right....
Doug
Old 08-16-2018, 10:12 PM
Correct! I wrapped masking tape on the shafts and drew an arrow on them in the forward rotational direction before I removed them, because it is easy to get confused once you get them off of the car.
When I saw the need to reverse the shafts I just installed them with the arrows in the opposite direction.
Old 08-16-2018, 11:03 PM
Nice. Great solution. I do this on my Vanagon during CV joint services an it is sooooooo easy to make a mistake.
Old 08-18-2018, 09:52 AM
No, it's not rotation direction that matters, but the torque direction. Flipping axles on same side retains same twist direction and torque. You need to switch left <--> right sides in order to reverse torque on the axles. Inner/outer position doesn't matter.
Old 08-23-2018, 04:13 PM
Yes, Danno is right. I had to stop and think about it Switching sides is the only way to reverse torque.
However, it is best to make the former inner the new outer to spread the wear if one end gets more wear. For instance a front shaft has the outer CV getting more abuse due to turning. So making that the inner would be good practice. Thanks Dan.
Doug
Old 08-23-2018, 08:19 PM
OP here, update and issue.
Innermost section is stuck to the axle. Cant get it off with all my might. What now?
Old 08-26-2018, 02:38 PM
..with the clip removed?
Old 08-26-2018, 03:26 PM
In the Fires of Hell.....
kdjones2000's Avatar
Remove the clip for sure then use a brass drift and a hammer to tap around it to get it to move...
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 08-26-2018, 03:31 PM
I had it happen once they do get loose but with lots of traction and loose bolt snap. I used stage 8 bolts so they dont loosen torque 5 lbs more if you use no gasket and the stage 8 bolts will fix the problem.
Old 09-05-2018, 07:18 PM
curtisr
curtisr's Avatar
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car)
1987 924s Garnet Red (with FIAMM air horns!)
1982 928 Silver (sold)
Old 09-06-2018, 06:26 AM
Be sure to clean off mating surfaces with acetone and be careful when installing not to get any grease between them. It's the bolt-tension that generates friction that keeps the two sides together and that friction transmits power across. Lowered friction from insufficient bolt torque or grease between interfaces allow slippage which breaks bolts.
I prefer blue loctite on the threads AND USE A TORQUE WRENCH!!! Torque spec is kinda high and it'll feel like you're gonna snap those bolts But that's really the correct torque. Grind 0.5mm off tip of cheesehead tool to make it wider and grip better. Also scrape all crud out of hole in bolt-head so tool can slip all way down.
Old 09-08-2018, 02:14 PM
