Rainwater in floorboards
We've had some fierce rains over the last week and I've noticed saturated carpet in both the front and rear floorboards. I've checked the door seals, the roof seals.Since there's a hump between the front and rear I don't think it's coming from the battery tray area. What other area might I be looking at? Unfortunately I haven't been in the car during the rains. I can always run it through a carwash I imagine
Old 08-19-2018, 04:17 PM
In the Fires of Hell.....
kdjones2000's Avatar
Battery tray, or possibly the tubes for the drains from the sunroof are detached/clogged.
Water will get to rear floorboard, no problems, from battery tray.
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 08-19-2018, 04:40 PM
Patrick
pfarah's Avatar
I agree; remove the battery and closely inspect the entire tray area. If it looks good, then it well might be the sunroof drains (forward side).
1984 944 NA, constant tinkering
Old 08-19-2018, 05:14 PM
I'd say battery tray, but it would be tough for that to get to the rear floor too. I'd say sunroof drains. BTW, my sunroof drains are perfectly clear, my car has brand-new sunroof seals, and the sunroof STILL leaks (drip, drip) in heavy rains.
Is it only the passenger side, or both sides?
Old 08-19-2018, 07:04 PM
Just the passenger side. I see nothing in the battery tray to indicate it would be the issue. I also blew compressed air in both drain tubes and they sound hollow. Where do they actually drain to? However, I did notice that the passenger door is leaving a gap of about an 1/8" -1/4"at the latching end. I don't recall ever having that issue before, so....
Old 08-20-2018, 04:20 AM
When my car did that it was the drain by the fuse box. I had to reach behind the wheel well liner to clear it out from behind. It looked clean in the fusebox area but water would not drain quickly enough in a downpour. From the wheel well it looked like a birdnest there was so much stuck in there.
2010 Cayenne GTS
Old 08-20-2018, 04:21 AM
Check the sunroof drains well. Don't waste your money on a car wash, just get a cup of water and pour it into the drains. You should see water coming out by the rear tire and behind the front depending on which drain it is.
Even with my sunroof drains clear, I still got water in the rear seat from a bad body sunroof seal which allowed water to come down the b-pillar and into the floorboard.
Old 08-20-2018, 06:19 AM
Poured water down all 4 & the only clear is behind the driver. Getting good flow at that one..more compressed air and we'll see what we shall see
Old 08-20-2018, 09:01 AM
drkshdw's Avatar
Use a piece of weed trimmer line and shove it down each of the sunroof drains. If that doesn't work, use a length of aluminum (soft) wire with the end tucked up and wrapped with electrical tape.
Old 08-20-2018, 10:24 AM
I second this, don't use compressed air. You can blow the hose off and it is less effective.
Old 08-21-2018, 04:06 AM
trevs911's Avatar
It looks like I have the same issue,only on the driver side . While running a hose on the windshield close to the wiper .I was able to put a mirror on the floor with a flashlight shining on the mirror that cast light up under the dash and looked in mirror to see up under the dash and I was able to see water coming in what look like a little pinhole or maybe even a weep hole but not sure where it is on the outside .🤔
Old 09-05-2018, 03:18 PM
Bradical's Avatar
Mine managed to soak the entire carpet, in front and behind the passenger seat- it was the battery tray, I dont have a sunroof. Just throwing that out there.
1988 924SE
2016 STI
PCA - Florida Citrus Region
https://instagram.com/bradical924/
Old 09-06-2018, 05:31 AM
