dcarlson's Avatar
removal of hood insulation adhesive
have we found best way to get this all off? I am being tempted to just get all the loose stuff and go over with the new pads.. thanks for any tips ('86 944)
'86 944
'86 911
07 cayman
Old 08-27-2018, 04:47 PM
Geoman's Avatar
I covered the engine bay with plastic sheeting and then used Pro-Power Goo Gone and several plastic scrapers to remove the adhesive. Using a heat gun speeds up the process. Worked well but it did take some time. I was able to get all the adhesive off and then wiped the hood down with acetone before I applied the new insulation.
Geoman
__________
1987 924 S
Old 08-27-2018, 07:34 PM
Misunderstood User
Not hard - cover the engine area and follow Geoman's advise. Take your time - it is worth the effort.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 08-28-2018, 04:17 AM
curtisr
curtisr's Avatar
3M makes an auto adhesive remover. It isn't bad.
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 08-28-2018, 05:21 PM
dcarlson's Avatar
thanks for tips - tried the goof off stuff and plastic scrapers -got most of it anyway - hope it's enough. what a b**** . How about this: drained old coolant and the radiator plastic drain screw head breaks off when tightening it back in - just age/heat fatigue I think - did not torque it that hard - somethin' to keep in mind if you ever go there,,,part available from our host. fwiw
'86 944
'86 911
07 cayman
Old 08-29-2018, 04:58 PM
Geoman's Avatar
Glad you got most of the adhesive off. Yup, it's a pain alright. But the new stuff will really look great. FWIW, if you install the insulation that has a self-adhesive backing, make really, really certain that you position it correctly because once that adhesive touches the metal, it's there for good! I peeled of the backing on only a small portion first and stuck that part down, then peeled the remaining backing as I pushed the material in place. Then check the position of the power steering reservoir. Had to lower mine down a bit so it wouldn't press against the insulation.
Geoman
__________
1987 924 S
Old 08-29-2018, 06:38 PM
