Tired Member
DaddyGlenn's Avatar
Rear defrost switch rating?
I am thinking about re-purposing the rear window defroster switch in my 1985.1 944 track car. If it can handle it, I will use it to direct wire the radiator fans.
Does anyone know how much amperage this guy can handle?
Glenn
Daily Driver - '78 911SC RoW, Track - '85.1 944
Support vehicle - '00 Suburban 2500 4x4
Wife's - '11 Mini Cooper
Son's - '85.1 944
Old 08-31-2018, 06:36 PM
drkshdw's Avatar
How many amps is the fuse that switch is on? I would assume that's how much it can handle.
Old 08-31-2018, 06:41 PM
Tired Member
DaddyGlenn's Avatar
Calling me out for being lazy, huh? I see how it is. Just kidding.
Really that is a no-brainer. I should have thought of that, but didn't. Thank you. And now that you suggest it ... the wiring diagrams say 8 amps, which is too little. I need at least 25. But, hey, the relay is 25 amps. So I could relocate the relay and use that to carry the load of the fans.
I'll have to see how much work that would be.
Glenn
Son's - '85.1 944
Old 08-31-2018, 06:59 PM
drkshdw's Avatar
HAHA!!! Sometimes the most obvious isn't the most obvious at the time.
Now as far as running the fans through the relay, I have no idea how you'd go about doing that. There are plenty of racers that direct wire the fans but I don't know how or where they get power or control them. Perhaps a search in the turbo forum would yield some more clues than just here.
Old 08-31-2018, 07:41 PM
Tired Member
DaddyGlenn's Avatar
I did do my research for how to direct wire the fans. It seems the popular method is to run a wire from the ground wire for each fan to a switch and then ground. I am looking for a more elegant solution. I've located where I can tap into existing wiring under the dash. Just need a good switch or switch/relay solution.
Glenn
Son's - '85.1 944
Old 09-02-2018, 06:46 AM
Pauld_94S2's Avatar
Use a relay, it's easier and safer.
Then you can use any switch on the dash you want.
Old 09-02-2018, 07:39 AM
