Driver
Brake job question
Hello all,
It has been a long time since my last post (4/2015 to be exact). I had a fairly debilitating injury that kept me from actively wrenching for awhile so I could use some advice.
This is a 2-part question:
I have been driving the 944 ('87 NA) off and on and getting some things done but I noticed recently how far down I need to press the brake pedal before it stops. It seems to go pretty far down toward the floor before it starts to brake.
The brake fluid level looks fine and I don't see any leaks so my 1st order of business is going to look and see what the pads look like.
PART 1 - Assuming I need to do the brakes I would appreciate making sure I am not leaving anything out of my parts list to do the front brakes.
  • 2 front rotors
  • Set of front brake pads
  • (4) Retaining Pins
  • (2) Spring Clips
  • (4) Securing Clips
  • (2) Retaining Springs
PART 2
If this doesn't fix the problem, where do I go next? My thoughts are, in order:
  1. New brake fluid and bleed
  2. New master cylinder.
Is there anything I am missing or doing out of order?
All thoughts are appreciated.
Thanks in advance,
GHEN
'87 944
Old 09-11-2018, 04:13 AM
Misunderstood User
seal kit for cylinders?
hoses?
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 09-11-2018, 07:30 AM
Pauld_94S2's Avatar
Reverse of your list, I would suggest that you start with bleeding the brakes first to make sure you have good fluid and no air in the system.
Failing that, it is possible that the master cylinder has a problem.
Old 09-11-2018, 07:45 AM
you might go for a spin to see if a corner is warmer than the others. increased pedal travel could possibly be due to a caliper piston not self adjusting on its seal/wiper.
Old 09-11-2018, 09:03 AM
Driver
Actually, that is a really good idea, thanks!
'87 944
Old 09-11-2018, 09:54 AM
