Driver
I need new front suspension
Hello All,
I took my '87 944 NA in today to get an alignment and they called and told me I needed new front shocks, as the right one is no good. Without having seen it yet the gentleman on the phone said I should replace the whole assembly, and in fact I should do both the left and right at the same time. He doesn't do this type of work so he isn't trying to sell me anything. So where do I go from here? Does anyone sell the entire assembly, or do I need to buy the parts all separately? If I have the entire assembly I can swap them out but I don't have the ability to compress the springs myself so any suggestions are appreciated. GHEN
'87 944 |
In the Fires of Hell.....
Get a compressor from your FLAPS. You will need to do the "hacksaw mod" on your struts...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Driver
The "hacksaw mod" means cutting it open at the top, replacing parts, and re-welding correct? Can you point me toward any info on this? Thanks! GHEN
'87 944 |
Friendly Local Auto Parts Store. You can rent the tool from them for free usually.
Look at Koni 1414 strut replacements on Paragon. They have everything you need.
Don’t mess about with inserts which are not stock spec anyway. Do as your mech told you and buy two new genuine Porsche (boge/Sachs) front struts and swap them over. If you swap them in yourself it will cost you $600 tops and they come with a 2-year Porsche warranty.
Best prices are from the Porsche dealers who sell parts online like Sonnen.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. Last edited by 9FF; 09-14-2018 at 08:40 AM.. |
Driver
GHEN
'87 944 |
I’m working on getting some pics and info over here on the struts ... stay tuned...
The factory struts are remarkably good and long-lasting IMO. Maybe not at top performance but acceptable and safe after many years and miles. Therefore IMO it's not crazy to put on a good used pair after making sure they have decent damping, possibly comparing to what you have now. Of course new is better if you can afford it or if the car is nice enough to warrant the expense. Sometimes you can get good take-offs from someone who is upgrading or from a part-out.
-Joel.
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
Driver
It turns out my car had Koni sport shocks that came original from the factory as an option. I am having them rebuilt by TruChoice.
Would still love to learn more about these cars suspension. GHEN
'87 944 |
