Driver
Do I need to remove the races?
Hello all,
I am putting new inner and outer wheel bearings in my front wheels.
I have both bearings out, the races are still in the hub.
Is there any reason they have to come out, or can I just put the new bearings in after packing them with grease? I mean, I will just have to turn around and put the races right back in right?
I feel as if I am missing something lol. The bearings are the roller bearings, and the races are the solid, round pieces of steel. I have the outer bearing (fell out when I took the wheel off). I have removed the dust seals and the inner bearing was underneath that, I THINK I have all of the bearings I should have.
GHEN
'87 944
Old 09-23-2018, 11:07 AM
944 S2
944 S2's Avatar
Didn’t the new bearings come with new races?
I would replace both. The races should be press fit.
Old 09-23-2018, 11:46 AM
Mike80911's Avatar
Location: New York Where only a criminal can have a gun
Go to one of the auto parts stores that loan tools and get the installation tool. They come out pretty easy with a punch and install easy with the tool no reason not to change them. As stated they should be included with the new bearings
86 930 Grand Prix White
04 Cayenne
1970 Chevy Nova SS
Old 09-23-2018, 12:13 PM
9FF 9FF is offline
9FF's Avatar
Never heard of anyone just using half a new bearing, why would you do that other than laziness. The races are part of the bearing and they generally wear together. If you fit new ball bearings into worn races, it’s likely the new bearings won’t last too long.
Get a brass punch and work the race out carefully so as not to make contact with the alloy hub with the punch. There are cut-outs on the hub to provide access for a punch, takes a couple of minutes for each race.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 09-23-2018, 12:40 PM
Driver
To tell the entire story, I don't have the new bearings yet, I figured I would see what came out of the hubs and buy what I needed. I didn't know new races came with the bearings...glad I asked the question.
Ignorance, as stated above. I didn't realize they came together.
This is the answer I was looking for, thank you.
LOL, if only it was that simple. Like everything else on this particular car, the races are fighting me. I have massively deformed my brass punch.
.....In a perfect world.
Thanks for all of the kind replies, massively helpful!
GHEN
'87 944
Old 09-23-2018, 01:06 PM
it is best to heat up the hub in an oven to 225-250 degrees F to remove and install the outer races. you should still use a press to be sure the races are bottomed in the hub and it helps to chill the races in the freezer. with the temp differential, they pretty much drop in.
Old 09-23-2018, 01:38 PM
9FF 9FF is offline
9FF's Avatar
Originally Posted by GHEN View Post
...LOL, if only it was that simple. Like everything else on this particular car, the races are fighting me. I have massively deformed my brass...
Brass usually works if the hubs have been heated first as thomasryan suggests, you can use a steel punch, just be careful to not score the hubs. Line up the punch in the cutout and tap it with a heavy mallet, firmly securing the hub in a vice really helps. Work both sides evenly through the respective cutout and the race should shimmy out.
Mike A
Old 09-23-2018, 02:10 PM
Driver
I heated the hubs with a MAP torch for a bit and am using a vice, I finally got the races out of one hub but the other is still fighting me.
I re-faced and re-formed my brass punch and went back at it, but didn't heat again.
I wonder if I throw it in the oven will my kitchen smell like old grease? Mrs. GHEN wouldn't like that.
GHEN
'87 944
Old 09-23-2018, 02:28 PM
Tired Member
DaddyGlenn's Avatar
This ^
Glenn
Daily Driver - '78 911SC RoW, Track - '85.1 944
Wife's - '00 740iL (Sport),
Support vehicle - '00 Suburban 2500 4x4
Son's - '85.1 944
Old 09-23-2018, 02:38 PM
"I wonder if I throw it in the oven will my kitchen smell like old grease? Mrs. GHEN wouldn't like that."
Wouldn't have the 'nads to try that one...try MAP again It will come out eventually!
Bruce P.
1988 951 Alpine White, AutoAuthority chip, HRE custom wheels, 10 speaker panels, Schnell short shifter, M030 sways, Koni Sports
"You're the best I ever had" --JJ Cale
Old 09-23-2018, 06:26 PM
