Preserving Dash - Keeping It Crack Free
Hi:
My '87 944 turbo is in immaculate condition. This is where I'd appreciate your advice. What would you recommend to clean and treat the dash? Mine has no cracks and I'd like to keep it that way. Thanks for any suggestions you might provide. Thom
'87 951 '01 986S (Sold) '78 924 (Carburated; sold when moving to CA) |
Hi all:
While I couldn't find this using the Forum's search function, I did come across this thread using Google. Best Dash treatment? Hope it helps others... Thom
I had a crack free dash and then I fixed the AC! The dash split between the two vents in the center. Unfortunately if the dash has dried out the thermal cycling from the hot sun to cold air can make it split.
1987 944 Summer 2006 E90 Winter |
I've been using Vinylex with good results. I have also heard good reviews on Aerospace 303, but never tried it.
I think the best protection is to keep the UV off the dash as much as possible. Garage is preffered, if not possible cover or sheild the dash whenever it is parked. Congratulations on finding one of the few out there!
Bruce P. New to me 2011 Cayman Base, LSD, Sport Chrono. 1988 951 totaled and missed ![]() "You're the best I ever had" --JJ Cale |
Use a dash cover:
https://www.covercraft.com/us/en/dash-covers? Use a windshield sunscreen: https://www.heatshieldstore.com/car-window-shades/1987-porsche-944-coupe BTW, Heatshield also makes a sunshield for the hatch glass. And get a car cover, Coverking or Covercraft. |
Misunderstood User
There isn't allot you can do -
keep it in the garage keep it out of the sun don't use water based protectants Put a cover over it I have an old style dash and I had it recovers 12 years ago. The dash is made from, what appears to be, a paper based material. There are several previous posts as to how many have repaired the dashes - I'm not sure one is better than the other. Recovering a dash is expense, which is why many opt for a cover. There are pro and cons with a cover - the fit seems to be the issue. There is no good answer.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
darnellsgarage
Whatever can be done, I haven't been doing it. I've had one 951 for over 20 years, and I'm on my third dash, and now this one has cracks too. It is always garaged and I don't put any product on it. The comment about A/C is interesting. I do blast A/C in the summer.
I've got a second 951 that probably has the original dash. Its a low mileage car, always garaged. No cracks. I think its just random.
don |
I've had a number of these dashes for over 20 years without issue and keep mine well lubricated with Meguiars #40. Works great and has a nice medium sheen when first applied.
Thread Tools | |
Rate This Thread | |
