944/1 windshield wiper motor alternative write-up
To begin with how this started, the plastic gearing in my wiper motor had stripped. I was unable to locate a used one and did some searching for an alternative option. I came across this thread and figured I would try it. https://rennlist.com/forums/924-931-944-951-968-forum/766142-wiper-motor-bit-the-bullet-again-996-part.html With the new motor installed, everything operates perfectly with the intermittent, low, and high speed.
I ordered a used windshield wiper motor (Part# 0390241350) from a 97 Porsche 986 Boxster. When I received it, I removed the plastic to see the internal contact points. They are almost identical; however, the inner and outer contact points are reversed on the new motor. 944/1 http://forums.pelicanparts.com/uploa...1545958140.jpg 986 http://forums.pelicanparts.com/uploa...1545958140.jpg http://forums.pelicanparts.com/uploa...1545958264.jpg I used the original connector and wired the motor to match the corresponding contact points on the new motor. http://forums.pelicanparts.com/uploa...1545958309.jpg http://forums.pelicanparts.com/uploa...1545958309.jpg http://forums.pelicanparts.com/uploa...1545958309.jpg When first trying to line up the motor to the bracket, there was a screw on the motor preventing the holes from lining up. I used a dremel tool to cut a small section of the bracket. http://forums.pelicanparts.com/uploa...1545958391.jpg http://forums.pelicanparts.com/uploa...1545958391.jpg I thought I would do this write up to let everyone know that these wiper motors are another option for our cars. |
This is awesome thanks for sharing!!! +1
That's awesome, but who drives their Porsche in the rain!
Hah! Will have to remember this if I never need to replace mine. However, it just doesn't see rain. |
| All times are GMT -8. The time now is 11:17 PM. |
