-   -   VDO 80 psi oil pressure gauge with stock sender? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/1017798-vdo-80-psi-oil-pressure-gauge-stock-sender.html)
DaddyGlenn 01-11-2019 04:44 AM
Does anyone know if the VDO 80 psi oil pressure gauge will work with the early 944 stock sender?
I'm looking at this gauge.
onZedge 01-11-2019 04:00 PM
That is exactly the same VDO gauge I have in my car with a stock sensor.
Reads around 80 PSI at cold start (at idle)
Reads around 35-45 PSI when hot (at idle) depending on ambient temperature.
Reads around 60-70 PSI when hot (at speed) depending on ambient temperature.
My background and profession is Steam Boilers, so all my gauges (and brain) are calibrated in PSI.
DaddyGlenn 01-12-2019 08:59 AM
ok, that helps. 5 bar is a little more than 72 psi, so I thought it might work.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
