strath44's Avatar
Are these Fuchs?
Hey all, I came across these recently and yes they look rough! I can't see the rear of them to check for part numbers. Are there any tell tale signs of them being Fuchs or not. I suspect they are not due to the amount of rust and the highly recessed lug holes but can anyone else give a better shout??!!! Cheers
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 01-21-2019, 08:16 AM
9FF 9FF is offline
9FF's Avatar
I’d say they are not genuine for the same reason you spotted, those lug nuts are meant to stand proud of Fuchs and not sit recessed into the wheel. Even if they are genuine they are 30+ year old wheels that have obviously not been looked after and are worth scrap at most. I can see just from those pictures that they’ve been curbed multiple times and fitted to the car incorrectly. The 8in seem to be on the left side of the car and the 7in on the right side and who puts wheel weights there on Fuchs
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 01-21-2019, 08:30 AM
strath44's Avatar
Good spot on the off sets on opposite sides! The common replicas don't seem to have the lugs recessed has anyone any pics of this else where can't see any!
Yes not good nick at all but I'm considering doing them all over satin black as a spare rough set and they are miles from me so would need shipped!
My first set of Fuchs on a Porsche had stick on weights on the outer rim the mind boggles. That would be in my top Porsche sins along with calling any pre 1985.5 944 an S2 in adverts and calling cookie cutters, Fuchs!!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 01-21-2019, 09:04 AM
Could just be short lugnuts.
Cleaned-up Fuchs are worth pretty penny. The 911 guys will give lots for 16x8". I sold my last set for $1850.
Old 01-21-2019, 10:34 AM
strath44's Avatar
Indeed they are worth a pretty penny!
I’ve acquired then sold at least 4 sets over the years, the first ones I had I hand polished the whole wheel - they looked great!
I really want a set to keep rather than punt on, these are indeed rough but might be able to do something with them if the price is ok!
Old 01-21-2019, 01:47 PM
FrenchToast's Avatar
16x9s have recessed lug holes, as do the 951-specific Fuchs.
The rust is just brake dust.
Nothing to me says they are guaranteed replicas. Would require closer look to determine.
Fuchs for a long time had weights on the outside. The balancer technology to put weights on the inside was not always commonplace. Outside weights are typically more effective anyway.
Except for clip-on weights, which are stupid (don't work on Fuchs anyway).
Old 01-21-2019, 03:50 PM
9FF 9FF is offline
9FF's Avatar
Originally Posted by FrenchToast View Post
16x9s have recessed lug holes, as do the 951-specific Fuchs...
Never knew that, thanks for the clarification.
Are they really still desirable being so old and obviously fatigued? I wouldn’t put my trust in a set even if they’ve been refurbished unless they’d been professionally trued and magnafluxed. I know Harvey Weidman does the full pro refurb to factory finish, those I’d pay for.
Mike A
Old 01-21-2019, 04:33 PM
strath44's Avatar
Thanks for all the input, as I am unable to view them I have gambled and pulled the trigger at £180 all in (thats $233 inc taxes and shipping for the 4).
Depending just how bad they are they will get a full refurb, they aren't going on a track or even fast road car so I'm not slightly worried about fatigue! Failing that they will be weighed in for scrap!!
I will post up back the results whether there is a little fox staring back at me on the inside or not!!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 01-22-2019, 08:43 AM
I know the 9s do. And from pictures the 951 P/N wheels appear to have recessed holes.
And yes, pretty sketchy to use Fuchs for regular performance use, given their fatigue. Fuchsfelge does batches of new ones every few years or so. However, new wheels still use a design that is over thirty years old.
I imagine you are aware that they won't fit a 1991 944. Not properly, at any rate.
Old 01-22-2019, 01:04 PM
ernie9944's Avatar
Easy to spotted a real Fuchs from Replicas,take one off & check the markings inside ,it should have markings as in the pics ...triangle ... and with the little foxe head ...
..also pics of a Carrera Fuchs wheel.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 01-22-2019, 03:21 PM
Most of the reps have thick metal that make up the "petals" of the wheel. They're most often cast, not forged and that means lots more metal is needed to hold things together. Also the backside will likely feel smooth(er) on a fuchs wheel, and rough on the back of a cast wheel.
So, if you can't take off the wheels, feel the thickness of each spoke with your fingers and if they're thick, most likely reps. If thin, most likely real. If you have a known real set of fuchs to compare, that will help if you're not used to making the comparison. But as mentioned above, find the part numbers to know for sure...
Old 01-22-2019, 04:03 PM
Custom User Title
mikepellegrini's Avatar
Another tell is real Fuchs are super light.
83 944 NA - Black on black
86 951 - Red
16 Ford Expedition
He who hesitates is lost.
Old 01-22-2019, 06:46 PM
strath44's Avatar
Thanks for all the useful insights folks!
Well remarkably having bought these and paid mid afternoon yesterday they turned up this morning which is lightening fast, I expected maybe next week!
Sorry not many pics yet but whatever they are, they are in much better condition than I expected! One has some pitting on the rear and all have about the thickest coat of brake dust I have ever seen which I assumed in the pics was rust. The kerb rash is not to bad and definitely fixable.
I don't have any time nor tools and the sender has made a very crude attempt to locate an offset for me on one which has exposed a makers serial seen in the pic which is very hard to make out at a glance one has something like FCO stamped on the rear of a petal and they feel pretty light! Sorry dreadful image but attached it anyway.
Once I get them under the pressure washer at the weekend I will post proper images. I hand polished my last set which I will not be doing with these as the upkeep was too high. I'm probably going to go stock with satin black centres.
Can they be sandblasted?
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 01-23-2019, 03:05 AM
the lip is anodized which is quite delicate.
iron-x will remove the brake dust chemically. it has worked well for me on similar looking caked on brake dust. mechanical removal might have disastrous results.
Old 01-23-2019, 03:43 AM
strath44's Avatar
thanks! Sorry when I say sandblasted I mean to take them back to bare metal to refinish.
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 01-23-2019, 03:58 AM
9FF 9FF is offline
9FF's Avatar
Those look like real Fuchs markings to me, I can see the fox and the 10.62 offset stamp for the rear wheel. Glad to hear they are in better shape than expected, regardless they’ll need some work you got a great deal!
Mike A
Old 01-23-2019, 04:01 AM
strath44's Avatar
Thanks they'll never be concours but I will do something with them!
1991 944 Turbo
2012 VW Passat
2008 Mini Cooper
Old 01-23-2019, 04:06 AM
951 version of Fuchs have these part#
16x7 = 951.362.115.00 , 23.3mm offset
16x8 = 951.362.117.00 , 23.3mmn offset
rare 911
16x9 = 911 362 119 00 , 15mm offset
Special thing about these wheels is spokes are shifted to outside more than regular Fuchs to clear large brakes. Hence sunken lugs look.
Old 01-23-2019, 11:20 AM
strath44's Avatar
Thanks for those, with nothing much more than water I cleaned up some serials it appears they match the 951 serials you posted danno!
The outer weight on one looks original and there are the strange valve supports which I’ve seen before!
The wheel in the picture is the worst the anodised rim is surface stained and some kerb rash which is less than 1mm deep.
I’ve never seen such thick brake dust they are remarkably unscathed underneath!
Old 01-23-2019, 01:30 PM
Be careful not to use any acid-based cleaners, they'll etch anodized layer.
Old 01-24-2019, 12:49 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
