Turn signal issue
Here’s a new version of an old problem. I have a 87 944 and the turn signals only work when the switch is pulled halfway down. If you flick it all the way the turn signal stops. All the lights work, flashers work, blinker lights come on and stay when key is off. Anyone have an idea, I am new on here and new to the Porsche world.
Question: Does it happen on both the left and right turn signaling? If it's one side, I'd suspect the switch is wearing out. This could be the same if the issues is on both sides, but I suspect the issue would not have started on both sides at the same time.
It does happen on both sides. They worked normal until recently then this started
Check the fuses for the lights, each bulb is on a separate fuse.
| All times are GMT -8. The time now is 08:22 AM. |
