thekidd's Avatar
Send a message via AIM to thekidd
no start, no crank
I have been trying to figure out whats wrong with my car, but too dam cold and wet here in E. PA covered IN 1.5'' of snow. In the past 2 weeks my car hasnt started twice. The first time i was at a store, shut the car off for a minuets, came back out, and nothing. The dash lights came on, no tach bounce, I heard fuel pump buzzing. Tried jumping, and still nothing. Went back to my house, got another car, drove with a starter, and a battery. Did nothing to my car, and she started right up. The other day I go to start her and the same symptoms. A few hours later I go to start her up, and she fired right away. Ever since that last start up, she has been sitting in the driveway. A weird thing that I noticed is that when I was driving the buzzer would be on, more often than not. Put in new reference sensors (for the no tach bounce), a spare starter, and switched out batterys a few times. Before I put the other starter in, I didnt hear it. I put the other starter in, and I would hear it the first few times i tried to start it, then it would stop, take the key out, and I would hear the starter again. I took the buzzer and 3 other relays (not DME) try and started her a few times, and heard the staretr going every time.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 02-03-2011, 10:26 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Check on your ground cables and make sure they are getting good contact.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 02-03-2011, 11:18 AM
944sracer's Avatar
no start, no crank
Could also be the actual key cylinder itself. If it is loose if abused then it will wiggle out of place when you turn the key.
89' 951 Turbo S Race Car - SP-3, PT-B
87' 944 Diamond Blue Metallic - DD
"Practice does not make perfect. Perfect practice makes perfect" - Ross Bentley
Old 02-03-2011, 11:47 AM
thekidd's Avatar
is it posible for the key cylinder to break? I put a new ignition switch in, was slightly cracked, tried to start the car- nothing. I took the ket out and the metal peice that opens when the key goes stayed open and the buzzer keep buzzing untill I hit the cylinder to shut it and the buzzer would then go off. I readjusted the reference sensor, still no tach bounce.
Old 02-05-2011, 07:21 PM
porscha
matty89's Avatar
check ur cables on the starter if they are good you could be looking at a ignition sw or a starter i didnt look at the electrical shema yet good luck !
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh
Canada , Quebec
Old 02-06-2011, 06:01 AM
i'm experiencing issues with my 87 924s (no start no crank) that seem very similar to the symptoms mentioned above.
OP, did you ever solve this problem? If so what was the issue/solution?
Any help is much appreciated!
Old 03-12-2019, 04:57 PM
I just went through the same thing. One day it would start one day it wouldn’t. No tach bounce checked the usual things nothing. Ended up being the ecu. I changed it out and no problem starting up.
78 911 st backdate
87 944
00 996
Old 03-12-2019, 05:37 PM
