944 Leaking Water
How do I prevent water leaking from thr battery compartment down to the passenger side? Are there any fixes for this? Also it's an 87 944.
Make sure the drain holes in the front of the try are clear, otherwise remove the battery and seal the rust hole underneath it befor the water destroys the DME.
