Clutch disc question
I purchased a Sachs clutch kit a while back for my 924s and never bothered to open it until now. To my disappointment the clutch disc included with the kit has the old style rubber puck in the middle. My question is can I keep the pressure plate from this kit and just order a new disc or will the new disc also require a different pressure plate?
Old 02-12-2019, 03:04 PM
9FF 9FF is offline
9FF's Avatar
Why not install the rubber puck version, itís a good clutch that will likely perform and last just as long as any other. My original lasted 140k miles before it went into ďget you homeĒ mode.
Old 02-12-2019, 03:24 PM
The pressure plate for the rubber center and the spring center disk are the same.
That said, a new rubber center will likely last 15 years or 100K miles, at least, and be quieter.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 02-12-2019, 04:11 PM
The kit is dated 1994. Even though it was sealed I don't wanna put my trust in a 25 year old piece of rubber. I didn't even realize people still ran these I thought they were long gone
Old 02-12-2019, 08:47 PM
9FF 9FF is offline
9FF's Avatar
Wow thatís old, shame really. People donít use them because they are expensive and they'd rather buy the cheaper, aftermarket non puck versions instead. I wouldnít hesitate to use it if it wasnít old stock, itís a superior clutch design to a simple plate.
Old 02-13-2019, 03:22 AM
I do not think it'll deteriorate in the box but if it'd stress you out there is no point in running it.
Having run the rubber and spring versions back-to-back the rubber hub version is really nice for NVH.
1987 928S4
1992 968 cabrio
1994 968 cabrio - Supercharged
Old 02-13-2019, 03:54 AM
Anyone here use centerforce clutch discs before? I'm looking at getting this one as I can only find the Sachs on it's own in 240mm. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F19 2818793717
Old 02-16-2019, 12:15 PM
Yeah...good stuff I have the stage II setup with the pressure plate love it!
Old 02-17-2019, 01:23 PM
Oh! And get your flywheel and pressure plate resurfaced for it to mate properly
Old 02-17-2019, 01:27 PM
https://autoplicity.com/
Found it at the above for $191.25 with the pressure plate.
Old 02-17-2019, 01:40 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
One thing I have noticed after replacing the rubber centered clutch on two cars (along with a short shifter kit) is a loud buzzing in the shifter handle under heavy acceleration. I assume that is due to the springs in the disk.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 02-18-2019, 05:41 AM
Not sure. I guess that depends on your setup...I have the CenterForce dual friction stage II clutch and pressure plate with an aftermarket flywheel the P.O. installed I just had it resurfaced. All I can say is I love it, I did not hear any buzzing noises at all when i had one installed in my 8v. I will see how the 16v treats me it has the OEM flywheel as far as I know and I am sure the dealership resurfaced it already....could the buzzing sound be apparent or louder if the little sound deadening and rubber boot material is missing from around the gear shifter itself?
Old 02-18-2019, 12:02 PM
I can still use Sachs pressure plate with Centerforce disc right? My problem is I've already got a new Sachs pressure plate that I don't want going to waste
Old 02-18-2019, 01:27 PM
I don’t see why not the centerforce pp looks like it was built off the Sachs core
Old 02-18-2019, 03:38 PM
John just posted in another thread that he has a bunch of low-wear Sachs discs.
No affiliation. www.porsche944usedparts.com
1987 928S4
1992 968 cabrio
Old 02-19-2019, 06:33 AM
