Yellow Crud Inside Throttle Body - 86 944 NA
I'm in the middle of diagnosing a starting issue, I pulled off my J hose to replace the Temp sensor and found this crud sitting inside the throttle body and slightly into the J hose. It wiped right away and wasn't anywhere else that I could see (I didnt open the throttle body) but I'm clueless as to what it is, any ideas? Whats a good cleaner, brake fluid?
I've only owned the car for a couple months so I don't know the maintenance history, it ran perfectly until a starting issue that is unrelated (I assume) Pics below: Last edited by jwolfe; 02-15-2019 at 03:43 PM.. |
At first glance, it looks a little bit like the "milkshake" you get when the head gasket goes and you mix oil and coolant.
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway) Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver |
Others who have had this problem said it was a seal at the AOS and/or oil cooler that needed replacing. |
Sent from my SM-N950U using Tapatalk |
944 addict
I'm wondering if the oil cooler seals had been replaced at some point, due t failure, but the oil had not been changed quickly enough and as such (due to faulty AOS seals), the crud got into the intake and was never cleaned out. If you currently have a clean dipstick, then the oil cooler seals are probably ok but a thorough rebuild of the throttle body is warranted.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
AOS seals are definitely at fault here. In regards to the the "milkshake" you have going on, its most likely just moisture in the oil that hasn't evaporated. I bet you don't drive this thing much? If that's not the case it may be your oil cooler seals, make sure your oil/coolant are both clear
Jwolf...Why don't you give your body throttle a good clean up reinstall it & drive around for a while see what it does .It might be that the probleme is all that was mention above by different persons,but it could also had been cause by the oil cooler giving up at one time or the other & they never took the time to check & clean the body throttle.
Thread Tools | |
Rate This Thread | |
