theer's Avatar
85.1 944 with factory sport suspension: shocks & struts
I have a fairly original early 944 with factory sport suspension. Shocks and struts are needing replacement.
It looks as if the rears are original - I can see yellow under the 35 years of dirt - so it's possible the fronts are original as well.
Does it make sense to have these rebuilt? Are these factory "sport" Koni shocks & struts available new?
Thanks,
Tom
Old 03-14-2019, 01:02 PM
Koni can rebuild them. That's what I'd do.
Old 03-14-2019, 01:21 PM
9FF 9FF is offline
9FF's Avatar
Check your options code decal, if they are original “sports” versions then you’ll have either M030 or M474 as an option code.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 03-14-2019, 01:23 PM
theer's Avatar
It's actually the M456 option code (also M220 for LSD).
From my research, the springs are allegedly shorter, so would need shorter shocks/struts(?)... Lots of conflicting information out there on these early sport suspension optioned cars.
Old 03-14-2019, 01:54 PM
9FF 9FF is offline
9FF's Avatar
Gotcha, iirc M456 was a package for early cars including sways and sports shocks. The sways are easy to look up but the shocks I can’t help you with. Are they simply valved differently or are they single/double adjustable? I don’t have much experience with early cars. I’ve heard people get the 030/474 rebuilt by True Choice (no affiliation), might be worth giving them a call and quote them the part numbers to see what they can do for you.
Mike A
Old 03-14-2019, 02:25 PM
Coeur d'Alene, Idaho
Pardon the bandwidth, but where is the options sheet/sticker on my 84? Thanks in advance.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 03-14-2019, 05:51 PM
9FF 9FF is offline
9FF's Avatar
It’s in two places, first page of the service book and attached to the car between the rear tail lights under the hatch carpet.
Mike A
Old 03-15-2019, 06:17 AM
Thanks. When I replaced the shocks and struts I got the standard OEM type and I'd hate to find out it had a suspension option I should have known about. It's still in winter storage, so I'll find out later....
Old 03-15-2019, 07:30 AM
9FF 9FF is offline
9FF's Avatar
You may also find this useful: Option Codes
Mike A
Old 03-15-2019, 07:50 AM
theer's Avatar
Thanks Mike - I'll check out True Choice.
I these may be adjustable, but require removal to make adjustments? I won't be sure until I get them out.
Tanks again,
Old 03-15-2019, 12:11 PM
Banned from Boulder
My first Porsche was an 84 with M456
You can actually get the original (?) Koni strut inserts from Porsche for about $220/ea 94434305900
The original rear shocks are NLA
I just went with regular off the shelf Koni yellows.
Old 03-17-2019, 01:14 AM
