curtisr
curtisr's Avatar
Fuel injectors
Hi everyone,
I'm hoping someone can point me in the right direction for low-cost options for fuel injectors. Naturally I've logged lots of time checking online but perhaps I'm missing something such as a less expensive cross referenced idea.
Thanks!
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car)
1987 924s Garnet Red
1982 928 Silver (sold)
Old 03-15-2019, 05:32 AM
9FF 9FF is online now
9FF's Avatar
Cheapest option is getting them refurbished, Ive used Witchhunter in the past and was happy with the results (no affiliation).
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 03-15-2019, 06:20 AM
curtisr
curtisr's Avatar
A great suggestion, thank you. Confession time: I set one on fire while cleaning them. The alligator clip slipped off the connection and the spark took it from there.
Old 03-15-2019, 07:53 AM
Coeur d'Alene, Idaho
Mr. Injector is in my home town and he's done a half dozen sets for me. Has a national following among hobbyists and includes a "before" and "after" flow graph to show how he was able to match the flow for a smoother engine. Search for it in Coeur d'Alene, Idaho. Great prices and fast turnaround. I think it's $17/injector. Includes fresh seals, and he likes it when clients remember to indicate what cylinder number as he etches it on the body.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 03-15-2019, 08:36 AM
curtisr
curtisr's Avatar
+1 Thank you.
Old 03-15-2019, 01:04 PM
So, if you are missing one injector out of a set, go to ******** online. They are having a closeout on 944 parts now and have one new injector left in stock for $16, made by the Standard Automotive Company. FWIW
Old 03-15-2019, 02:05 PM
curtisr
curtisr's Avatar
The Thought Police heard you.
Old 03-15-2019, 04:26 PM
Checkout these guys I paid little more than a 100 for all four of mines
https://www.fiveomotorsport.com/catalogsearch/result/?q=944
Old 03-16-2019, 01:59 AM
curtisr
curtisr's Avatar
I am immensely grateful for the suggest. As one might expect, the passage of time has made a change to the price: they're now $68 each (with core charge).
Old 03-16-2019, 05:04 AM
curtisr
curtisr's Avatar
More on the subject.
https://www.motormanfuelinjection.com/PORSCHE_FUEL_INJECTORS.html
This chart helps with alternatives. The prices are still similar.
Injector Planet tells me the following good information but a search for the manufacturers' options only leads me to the same issue with time:
Bosch EV1 Fuel Injector
pintle nozzle
Flow rates @ 43.5 psi / 3 bar
24 lb per hour
181.7 G per min. (N-Heptane)
252.7 cc per min
2.35 Ohm resistance
Bosch 0 280 150 158
Renault 7700260543
Porsche 93060612000
Old 03-16-2019, 05:08 AM
0280150201 might be worth a look, there are some on Ebay listed as 944 injectors, some new options (including questionable Chinese knockoffs), refurb sets for cheap, even a 944 fuel rail and 4 injectors at a good price.
1987 928S4
1992 968 cabrio
1994 968 cabrio - Supercharged
Old 03-16-2019, 06:55 AM
have you tested existing injectors to confirm they are defective and need replacing?
Old 03-16-2019, 01:41 PM
Wow! How time flies, should have brought two set up then...looking at 400-500 new I am kicking myself right now
Old 03-17-2019, 04:52 AM
curtisr
curtisr's Avatar
I have cleaned them by using hose, injector cleaner loaded via a syringe, 12 volt battery. Is that the same thing?
Old 03-17-2019, 02:29 PM
curtisr
curtisr's Avatar
Crazy, huh?
Old 03-17-2019, 02:30 PM
I just installed injectors from AUS Injection in my 88 924S and started it up for the first time in years...
Old 03-18-2019, 10:48 PM
curtisr
curtisr's Avatar
Nice! So, four would cost $200. Not bad!
Old 03-19-2019, 10:23 AM
9FF's Avatar
Problem with AUS and others who simply batch buy used injectors and refurbish them is that you never quite know what you are getting. Luck of the draw you may get four OEM injectors or all fakes. Either way they will work to start with but if any are Chinese fakes they are likely to go out of spec or fail completely within short time.
I’d rather send my own in for refurb to a company that takes care to send the same set back rather than a company that swaps them out with refurbs they’ve got on the shelf. I also see that they are quite expensive ($49) for refurbed injectors whereas if you have your own done it’s half the price with Witchhunter or others.
Mike A
Old 03-19-2019, 11:42 AM
