Head gasket blown?
Opinions, please!
Well-cared for 1989 944 (2.7 liter) with 130K miles, all stock engine, just put back on the road after being up for 2 years. Car is running and I've been auto-crossing it. Yesterday a buddy helped me do compression and leak down tests. Numbers were good. Compression 200, 200, 205, 205. Leakdown numbers were 4% to 9%, the worst being #2. As I'm putting the plugs back in my buddy pulls out a borescope and we put it down #1. I see something strange: a drop of fluid, what looks like coolant, running down the cylinder wall. Piston and wall look good, BTW. My buddy thinks it might be oil, but it looks too thin to me. When I back the car up we have a lot of coolant on the floor... maybe 6 or 8 ounces. I leave the car running for a while but no more drips out. My garage floor at home is dry as a bone, but I had some coolant overflow at one autocross. Gotta be the 80psi leak-down air pressure forcing coolant out the over-flow through a slightly blown head gasket, right? Any other possibilities? Last edited by edfishjr; 04-01-2019 at 04:24 AM.. Reason: spelling |
Tell-tale sign of a bad head gasket would be your coolant bubbling while you were performing the leakdown. If that wasn’t happening I wouldn’t worry about it.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
Top up coolant and run it, check again for any bubbling in the coolant with the cap off and look for any white smoke at the tailpipe. If you’re not getting either you likely just had a minor coolant leak either from a loose clamp or from the overflow.
The engine was hot so we did not have the cap off when testing yesterday. We listened but could not hear any air noises at any time. |
Btw whenever I do a leakdown, as well as removing the coolant tank cap and looking for bubbles hinting at a head gasket failure, i also listen for air leaking in three areas. I remove the dipstick and listen down the tube which would point to rings. I open the throttle plate and listen for air leaks there which would hint at intake valves. An ear on the tailpipe can identify hissing that would point to exhaust valves. This likely won’t help you but it may help others searching here as I know a lot of folk simply do a leakdown for the numbers without identifying the actual cause.
I started it up from cold this morning with the tank cap off, looking for bubbles and listening for gurgles. When the heater valve opened up I got two or three bubbles but nothing more. I'm going to watch it closely. |
Headgasket failures typically do not spill any coolant externally. Usually it's sucked into cylinder and disappears out tailpipe.
Look under gas cap for chocolate milkshake. Also look at oil. ![]() ![]() |
Ugh! That's more like a mocha shake!
Another indication that something could be up is excessive pressure/bulging in the top coolant hose (coming off of the water neck). |
Thanks. So far no milkshake, no bulging hose.
