what parts? 944, game on!
Hey all, well, i'm getting very close to pulling the trigger on that cheap 83 944. many thanks to all of you who replied to my last post. I really do appreciate it.
Well here is the deal.
As you may recall, the timing belt went out this car while it was in the driveway. I have located 2 possible replacement heads for very little money. one of them was just milled and has been ported/polished w/ valvegrind. so that's the route i'm leaning, just cause i can.
well, i need to figure out all the parts i need and where to order them from, here is my list so far, and please tell me if i'm missing something.
waterpump, belts & roller kit, head gaskets, my buddy says to also get exhaust manifold gaskets or bolts ? not sure why though.
Is Vertex alright for 944 parts?
any help appreciated thx Kyle.
Old 03-18-2003, 10:57 AM
least common denominator
scottmandue's Avatar
Porsche Crest
Well I hate to point out the obvious (NOT)
Have you checked here at Pelican? (maybe you just droped into the BBS and are not aware they {Pelican} are a parts supplier)
Do a search here on Vertex I think some of the folks here were not happy with the service they got.
Good luck
1995 Miata Sold
1984 944 Sold
A lie can travel halfway around the world while the truth is putting on its shoes.
Old 03-18-2003, 11:30 AM
you are completely right Scott. what i really is a list of parts that i might need? i've never owned a 944 before, yet alone replaced the head on one. sorry for the confusion. Kyle.
Old 03-18-2003, 12:28 PM
Porsche Crest
Fortunately I have not had to do any repairs to the engine (cross fingers, and toes, knock on wood, rubbing rabbits foot)
Unfortunately I'm not a mechanic so when I take my car in for service in the next month or two I expect to shell out major dough for some of those parts. {Yeah, I'm paying a mechanic to work on my car - I know - I am big lazy wussy mama's boy poopy head}
Anyway if we can get the attention of some of the wrench heads around here, (many have done the job you are preparing for) they should be able to give you a heads up on the parts list.
1995 Miata Sold
1984 944 Sold
Old 03-18-2003, 02:30 PM
robs944's Avatar
Talking
Get the Head Set , this will include all the gaskets you will need including exhaust and intake. Around $75 - $100
It's a good Idea to get exhaust nuts, more than likley you will round off one or two during the removal. $6.00 (*****************)
You will also want to get the fuel injector seal kit, may not be neccassary but will save you grief if they get damaged during removal.
Personally I have not had a bad experience with Vertex.
Most of my parts came from pelican.
Not sure what your technical background is but How about a shop manual?.....Trust me!
See Ya!
Rob
87 944 * 89 951
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car."
Old 03-18-2003, 05:09 PM
Go the easy way, buy a kit for changing out the head. It has everything, including intake and exhaust gaskets.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 03-18-2003, 06:21 PM
ae1969's Avatar
Send a message via ICQ to ae1969
since the belts went on this car.....
- get the headgasket set
- new rollers, idlers, tensioners
- new water pump
good luck
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-18-2003, 06:52 PM
coupe's Avatar
Parts list
Get a new thermostat along with new seals for the water pump.
Get the Power steering and A/C belts, do them all along with the timing and balance shaft belts.
Get all new from end seals.
Good luck
coupe
http://www.p-caronline.com/directory/coupe
Porsche 944 Turbo, 1986
Fiat Coupe 20v Turbo, 1997
Old 03-18-2003, 07:00 PM
overkill's Avatar
Send a message via AIM to overkill
Valves, guides, and stem seals. Just to bring it to your attention, springs are expensive so whether you replace them is totally up to you, If one or more of your springs are damaged they might break and you'll end up in pearldrum's shoes or back to square one. Also, check you oil cooler and make sure it is leak free. It is alot easier to get to once the head is off.
{1987}944S - (SOLD).
Old 03-18-2003, 09:57 PM
AFJuvat's Avatar
Assuming the head has already been rebuilt:
definately get the headgasket set - when installing it, make sure OBEN is facing up.
New pump, thermostat
Rollers as needed - you can spin them and feel if they need replacing or not. If they are iffy - replace.
You may or may not consider replacing the front seals on the car - by the time you are replacing the waterpump, you are "right there" for all of them. It adds an hour or so to the job.
When installing - like the 911, nothing is torqued down by a gorilla.
Vertex - had mixed success with them myself.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-19-2003, 01:45 AM
Chris_924s's Avatar
Dont forget to get a water pump gasket.. Doh.
TENSION YOUR SOCKS!
88 924S Guards/ Black ~ 10 years as a Daily Driver and STILL SMILING!
87 NA Diamond Blue Metallic ~ Gone
Old 03-20-2003, 03:58 AM
944pete's Avatar
While you're in there it's a real good idea to replce the oil cooler seals. They're cheap (around $25) and it will be be a real easy job with the head out. If you don't change them they will leak sooner or later.
Pete
1989 944S2-Dove Blue Metallic
1985.5 944-Alpine White--sold
My P-car Online Profile
Old 03-20-2003, 06:44 AM
