is my motor 8 valve?
Kinda confused on this. It's a plain old '86 944 NA. thnx
'86 944 '86 911 |
Yes your 1986 is an 2.5 8v.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
Want to do that throttle cam upgrade and part I looked at is apparently limited to 8 valve.
'86 944 '86 911 |
Patrick
8 valve motor:
![]() 16 valve motor: ![]()
1984 944 NA, constant tinkering |
Northern Motorhead
The throttle cam "upgrade" will work with your engine , shop around they're available from different vendors for different prices !
Rennline sells them too now, although probably the most expensive ...
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
thanks, pics worth 1M words. 'spose that's DOH?.
'86 944 '86 911 |
Just FYI the round Throttle Cam (usually red) can be used on both 8 and 16v cars...
'86 944 '86 911 |
dcarlson...Showing you a throttle respond cam I install on my ex 83 944,that was years back.At that time you could only get it in brush alluminium.While it doesn't give you more horse power it does have quiker respond I love it.Also if you take a closer look a did install an Accel electronic coil which will give you more sparks.
Throttle cam on my 16v 87' S:
![]() You see, it can be done! I'm sure it is one of the best subtle or cost effective upgrades you can do to the car especially the S model. |
just a follow-up - did the throttle cam install - it is nice upgrade - just so much better pedal response - glad my clutch has only a couple thousand on it! Did that air box w/K&N give you any noticeable boost?
'86 944 '86 911 |
Just modify your stock one for free, it will function he same ( cut off arm and relocate the cable hole ( by drilling a new hole and cut a slot as the factory one) ...real simple and free.
Thread Tools | |
Rate This Thread | |
