Headlight and windshield wiper question
As we wrap up my son's 944 project we have a few more things on the punch list. Passengers side headlight on dim does not work but high beams do. What should I be looking for?
Also the driver side wiper linkage pops off.. Is there a replacement ball and socket I should look for? Also have intermittent speedometer but think we know what that is.. Thanks everyone for the help..
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
For headlights, check fuses 22 and 23. Each low beam (and high beam, for that matter) has its own fuse. Check the bulb. Check the grounds.
Good luck, George Beuselinck |
Found a bad fuse so 1st problem fixed thanks.. Now the windshield wipers. Any thought on that?
The headlight pivot balls are not separately replaceable. If they continue to disconnect, you may have to buy an assembly, which is not available new anymore. Check with your used parts guy...
Sorry not headlight pivots but windshield wipers pivots
Yeah, that's what I meant... finger check.
