944s2 brake refurb
Hey all, I recently pulled off the front brakes to my '91 and they're a bit beaten up and corroded. Originally I was just doing rotors and pads and then realized that I was getting some nasty plate lift due to corrosion and couldn't get the new pads in.
Here's a photo gallery of the worse of the two calipers. My question is if visually they look safe to rebuild (ordered the piston kits from our host). Never rebuilt calipers before. My friend managed to get the plates off by welding nuts to the screws (heads had long since ceased to resemble allen? sockets). I can take photos of different angles when I get back home... at work now and just had these on my phone. https://imgur.com/a/tnGyGxr Thanks!!
1991 944S2 |
I wouldn't bother there are so many cheap alternatives out there you could look into getting new OEM replacements or another Turbo's used brakes and there is even the Big brake Kits you could look into...I would do any of the above but waste my money, time and energy on getting those things back road worthy again...which from the looks of it...it doesn't look like those should go back on your car maybe soak them in some type of acid/crud remover solution and see what you have left...they are a real PITA to get back together though (speaking from experience) that is why I suggested to just buy new ones.
Don't mean to sound rude about it....but that is the way I would go. |
Misunderstood User
I would clean them up first and then look at them. If they were working, why not rebuild them?
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Sorry I meant new ones as in new used ones in better shape 👍 |
I'm pretty sure I've read through a few threads that you've posted on before and concluded that I should do this without splitting the calipers. Seems like it's okay to paint/coat and bake them assembled as well? Quote:
Good point! I'll clean 'em up.
1991 944S2 |
Yeah...I was just trying to save you some headache...However, I would love to see how they come out and what you do to them....hand-sand/Polish all the light rust off of those pistons so they will slide out and in smooth as butter! |
Thank you! I'll give an update here. Still looking for the screw size for the plates. edit: all done
1991 944S2 Last edited by Steelstorm; 04-29-2019 at 08:32 AM.. |
1991 944S2 |
Misunderstood User
Much, much better!
