Baza's Avatar
Wheel Bearings
I need to replace the rear wheel bearings, and I would like to know if I have to buy my bearings from local dealer or can I get them from local bearing trader? I only have the part numbers and not the size or type of the bearings Does anybody have this information?
One bearing is $83 here and I want two, doing both sides.
Always start with the cheapest option first
83 NA Gaurds Red ( Home at last)
Holden/Opel Vectra 2002
Old 03-19-2003, 01:42 PM
Pelican has good prices for rear bearings for 951's. Bought mine there several years ago. Local dealer will rip you off.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 03-19-2003, 02:05 PM
SoCal Driver's Avatar
There are two bearings in each rear side of an 83 944. One ball bearing and one roller bearing.
Are you sure you've been quoted for the right year? The post 85.5 has a single housing bearing that has two "bearings" in it and is quite expensive compared to the early bearings.
Also two seals and an o-ring per side.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-19-2003, 02:17 PM
