Major noise & vibrations on 944 85 1/2
I bought in July a 944 year 85 1/2 Auto Transmission - 64,000 miles.
Already changed timing belt, balance shaft belt, engine mounts, torque converter mounting plate. Flywheel is new (replaced before I bought the car)
However, I still have some very loud noise and vibrations when the engine is idle below 1000 RPM, in particular when I shift on Drive or Rear (because the RPM goes lower). Above 1000 RPM no problem. The noise seems to come from the front of the car.
The car has a history of loose bolts in many places (lost a rear axle one day!)
Anyone has an idea?
Old 10-22-1999, 08:28 PM
Check for a loose drive shaft flange collar. You can see it from the inspection port on the bell housing.
Good Luck,
Lee
Old 10-23-1999, 09:21 AM
