need help adding cruise control to my '84 944
I would like to add cruise control to my '84 car. I recently bought a parts car, that was partially stripped already, but it had the actuator, and the brain (i think that's what that silver box is)
My question is, what other parts besides the servo, cable, pedal lever, and brain do i need to complete the conversion. do i need a wheel speed sensor? where is the on/off switch located, and where do i plug it in. What other electrical parts do i need. Mike firnhaber@juno.com |
The speed sensor is located in the speedo. The switch should be on the steering colum.
Sounds like you have all of the other parts you need. |
Is the switch intergral with either the turn signal stalk, or the wiper stalk? or is it seperate? I need to know whick one to replace.
Where do i plug in the brain? my parts car was an '86 and i can't find a connector in the same location on my '84 Thanks Mike |
| All times are GMT -8. The time now is 06:04 AM. |
