Sternn's Avatar
Cylinder Head Issues
I have some questions about cracked cylinder heads.
First off, my car is STILL in the shop. It will be one year as of April 4th.
Second, after having the mechanic beat around the bush and give me every excuse, he finally gave me the date of this Friday when he would have the head back on and the car running. Needless to say he called today and has told me the 4th cylinder head has a crack in the sleeve and the sleeves can't be removed so I need a new one.
Then quoted me another $400 for labor not including the parts.
My question is can a crack be fixed? Also my car is a 944S - will the 944 N/A part fit this?
-S
- Sternn
- 944S - Project Car
- Web Master & Used Part Guru From
- www.stuttgartparthaus.com
Old 03-20-2003, 12:18 PM
AFJuvat's Avatar
400 in labor - for what? is the head on or off?
had the head a year and he is just noticing this now?
depending on where the head is cracked, it can be welded and machined. anything through the combusion chamber is a no go.
pictures, I want to see pictures....
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-20-2003, 03:25 PM
Sternn's Avatar
I went down there yesterday and looked myself. It's not visible to the naked eye, its a hairline, and it doesn't appear to be deep. I myslef think it's just a scratch, but they are letting me its a hairline fracture that more than likely goes all the way through. The only way to even see its there is to actually run your fingers across the inside of the cylinder. You can feel a little very very small groove which they say is a fracture.
Thats also why they say they didn't see it because it was covered in muck until they began cleaning the cylinders to prepare for the new head.
On a good note, the head is beautiful and ready to go.
I'm wondering if it's just a scratch if thats an issue, and if by some chance they are right, how bad would it be to leave it and not replace the small block.
Also with a 951 or NA small block fit an S?
-S
- Sternn
Old 03-21-2003, 07:26 AM
Sternn's Avatar
Just got word in a block from an NA will swap out, but I have to swap the pistons as well. Any possible issues with doing this?
- Sternn
Old 03-21-2003, 07:30 AM
AFJuvat's Avatar
ok, are we taling head or are we talking block?
AFJuvat
Old 03-21-2003, 09:04 AM
Sternn's Avatar
Block. The 4th piston cylinder is where this crack/scratch is located.
- Sternn
Old 03-21-2003, 10:16 AM
TSNAPCRACKLEPOP's Avatar
magnaflux, xray
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 03-21-2003, 10:22 AM
Sternn's Avatar
A 944 short block is made from aluminum, meaning magnaflux won't work :/
- Sternn
Old 03-21-2003, 10:38 AM
