Coeur d'Alene, Idaho
Distributor firing order check on aisle 3?
So my yellow spark plug placement sticker fell off the alloy cam cover. I taped it on with clear tape. The car won't start but will buck and snort. I'm wondering if I taped it on 180 degrees out as it will read either way. I marked the wires and such but still wondering.
Could someone tell me what wire goes on the dist cap at the 2:00 position is when viewing the dist as a clock face from the front bumper? I have cyl 2 there. Continuing clockwise, I have cyl 1, then 3, then 4. Correct?
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 09-24-2017, 06:51 PM
You're correct
Old 09-24-2017, 07:14 PM
Thanks!
Old 09-24-2017, 08:56 PM
rbuswell's Avatar
Porsche Crest Is the order different for a 924S?
Sorry for high-jacking an old post. I'm getting a 1987 924S rehab project back running hopefully. The car ran before the water pump froze. PO shut it down right away and parked it for a couple years. I installed a new pump and belts and timed every thing per normal. Tested compression and it was low but uniform. It has fuel at the plugs. I wanted to be sure I plugged the wires into the (new) cap right before I started to suspect everything else. Attached is a diagram from a 944 I snagged off the web.
Added comment: Forgot to mention that I also replace the wires with Clewett Racing. Checked spark at all four cylinders and I have a strong spark. They didn't look fouled. At this point, I guess that leaves timing.
1982 911SC
1987 924S
Old 06-05-2019, 08:52 AM
