996C2, 944S2 project
S2 Total rebuild
Hi all,
I live near Buckingham, I purchased a basket-case 944 S2 a few years ago, then found it had chronic problems in every area, from engine (cam cogs worn away) to body (multiple rust problems), to suspension (some actually rusted away), one wheel had a broken nut, so had to be drilled out, you get the idea...
The suspension, brake system and bodywork is nearly complete, so my next task is service / repair the engine and gearbox and then get the MOT and get her on the road. After that, all the details like interior, etc. can be done.
I would really appreciate some advice on the specific outstanding tasks?
1. Does anyone know where I can get a set of cams, either new or good condition?
2. It appears possible to swap Boxster seats right over, is this correct??
3. It really annoys me to pay 100 for a bonnet badge, they look identical and seem to have an identical fitting system, so does anyone know why a good used 986 or 993 or 964 badge won't fit?
Thanks for a very useful forum, and appreciate any advice!!
LoJo
Old 06-07-2019, 01:34 AM
does copper pass the MOT? it will fatigue and crack over time especially if is unsupported.
Cohline brake lines are quite reasonable at ten to twenty bucks for the double bubble sections.
some US dismantlers should be able to hook you up with a set of bump sticks or you might be able to have yours repaired.
Old 06-07-2019, 02:49 AM
The last brake pipes lasted for 30 years, and only needed to be replaced due to chronic corrosion, probably caused by road salt, so they have been replaced with the same...
Anyone know of a source of Cams for 944 S2??
Thanks -
Old 06-09-2019, 09:33 AM
Does anyone know where I can get some standard or very mild cams? Or have a way to repair the cogs on the cams??
Old 06-09-2019, 10:18 PM
In the Fires of Hell.....
kdjones2000's Avatar
944 Online I believe has a service to replace the teeth.
Call Ian up and ask him.
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 06-10-2019, 07:02 AM
Copper/nickel (cunnifer) or copper/nickel/steel is more common.
Old 06-10-2019, 06:04 PM
Thanks KDJones - I have sent an email to ask about the rebuild service -
Cheers - LoJo
Old 06-11-2019, 08:16 AM
Web Cams are really good and good price too. Just find your year model the link I posted is for a 1990 model
Web Cam Racing Cams Inc. / Porsche 944 S / S 2 DOHC 16v
Old 06-13-2019, 07:57 AM
