Gauges
Having some problems with my gauges. Fuel gauge occasionally jumps all over the place and usually sits on E and the Temp. gauge is starting to do the same. I pulled the cluster and checked the connections, when I unplugged the connector and cleaned up the terminals etc... it was ok for about a minute, then dropped back down to E. Went through and cleaned all the ground connections and cleaned the connections on the sender as well. All to no avail. Could there be anything else? Possibly the gauge?
'83 944
Forest Green
Old 03-23-2003, 06:25 PM
perfecto951's Avatar
Send a message via AIM to perfecto951
my brother has the same problem with his 87 n/a. i have no idea.
1986 951, India Red. (Mine) - Not For Sale Anymore
1987 944, Alpine White. (Bother's)
2000 Audi A6 2.7 Biturbo Melange (Mom's)
Old 03-23-2003, 06:39 PM
Thanks, if I ever do find out, I will let you know
'83 944
Forest Green
Old 03-23-2003, 07:03 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
sound like a short in the fuse panel..
My car is naughty
Old 03-23-2003, 07:57 PM
Christoph's Avatar
check your grounds......bad grounds cause eratic operation.
Old 03-23-2003, 10:16 PM
I have heard that if you take out the gauge cluster, and remove the little football shaped pieces from the back of the cluster and clean them and the little posts they are on with Lacquer thinner and put them back on, you will get better readings from the gauges. I did it and my gauge seem to read on a wider range now. Good luck
John
Old 03-24-2003, 11:26 AM
Thanks, I think mine is a little different though(83). There is only one connection for the whole gauge pod that the fuel gauge is in. I tried cleaning all the little connctors on there and it didn't make a difference.
I found out that there are a couple other grounds that I missed. I am going to give those a try and see what happens.
Thanks again.
'83 944
Forest Green
Old 03-24-2003, 12:53 PM
