Need help with airflow meter
The temp sensor in my airflow meter has gone wack making it hard to start when the engine is cold. The resistance in the air temp sensor circuit reads under 1.2K ohms when at approximately 20 degrees C. According to clarks garage the temp circuit should read between 1.45-3.3K ohms when between 15-30 degrees C. I find though that when I heat and cool the sensor it will adjust accordingly in terms of resistance but will slowly move out of range when it goes back to room temp. I have already cleaned and adjusted the resistor track in the meter and have made sure all contacts are clean and tight. I have also replaced the water temp sensor with no improvement. Car is an 88 924s. What do you guys think and where would be the best place to get a replacement meter? Thanks
Old 07-15-2019, 07:55 PM
curtisr
curtisr's Avatar
If you order today (or was it yesterday...) from plyhammer parts you'll receive a 15% discount. He was also offering a 10% off deal very recently so if you ask nicely I'm sure he'd cut you a deal.
I'd try a different DME relay for starters. lol
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 07-16-2019, 06:27 PM
I dont think this will have that detrimental effect on cold start considering we all using 30 yr old AFMs, if you want an easy enrichment adjust the FQS switch on the ECU, tension up the AFM spring one click etc Ultimately you will need to upgrade to a MAF or ECU upgrade as the cars become older.
Old 07-21-2019, 01:42 PM
Check ECT sensor resistance as well.
Should be done at DME connector to verify wiring in between. A LOT of times, sensor checks out fine when measured at sensor. But at DME connector, nope, kaput, zip because of crispy cracked wiring.
Old 07-21-2019, 05:03 PM
