85.5 Crank, No-Start, need more ideas
I have been chasing this issue since buying the car last Fall. The only way the car would start initially was 50amp setting on charger.
I have since gone through and restored and rebuilt the top end, full tune up, hoses etc. The engine fired perfectly on first crank. I drove the car around
for a few minutes and allowed to idle while I rinsed off the shop dust. The gngine quit soon after. I have verified timing belts/pulleys are still in place and not jumped.
I have perfect fuel pressure, spark, new ref sensors and harness etc.
The injcetor noid light begins to glow after 2-3 seconds of cranking and lightly pulses as cranking continues. I am suspect of the injector driver in DME.
Any ideas or items to test, please pass along. Thanks, NW
Old 08-04-2019, 05:47 PM
Need more definitive testing results.
1. measure peak-to-peak waveforms of speed/ref sensor with oscilloscope. What is this voltage-spread?
2. pull fuel-rail with injectors attached. Place little cups under each injector. Crank for 10-sec. How much fuel did you collect in each cup?
3. what is intake-manifold vacuum when cranking?
4. what is fuel-pressure in rail with vacuum hose disconnected?
5. what is fuel-pressure in rail with vacuum hose connected?
Old 08-07-2019, 06:22 PM
There's problem. It should be pulsing immediately. This is probably just effect, not cause of your starting issue. Probably speed/ref sensors need adjustment. Need to know exactly what their waveforms look like with oscilloscope though.
Old 08-07-2019, 06:24 PM
