LinkBack | Thread Tools | Rate Thread |
Air/Fuel/Idle Mixture Adjustment-924
In the Fires of Hell.....
Sounds like your WUR may be faulty.
I recommend you post on the 924board.org site - they are experts on your car.
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost 1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th 1987 944S - Restored salvage title, ready to live again I can fix your late 944 Cruise Control module - PM for details |
Sounds like you got some blockages in your WUR or FD. CIS cars are very sensitive to sitting and don't like old gas. Sometimes, fuel cleaner will help but likely you will be flushing parts and fuel lines to make it right.
Cheers Guys.
I've just replaced the Fuel distributor and have only run the engine briefly since replacing. It does seem as soon as the engine runs for about 5 minutes and get warm it wants to cut out. it's got brand new gas in it and also has had fuel cleaner run through the system. New plugs also. Do you know if WUR has a blue plug? If so, that connection does look dodgy on mine... |
CIS is a particularly old school, analog fuel injection system.
In a previous life, I owned 1980s Audis and VWs, which used the CIS system. My recollection is that you cannot properly diagnose running problems without the appropriate fuel pressure setup. Check with a local old guy who still has his CIS fuel setup for how to adjust the system. (IIRC, the electric plug on the WarmUpRegulator was to provide heat to change from cold running to warm running.)
Good luck, George Beuselinck www.944ecology.com Porsche Deconstructor (tm) We buy 944s and sell 944 parts (845-379-1944) We rebuild torque tubes and instrument clusters for 944/968/928 |
Thread Tools | |
Rate This Thread | |
