A/C Compressor Removal
I recently bought a 1988 944s from a guy and he said he was fixing the compressor mount and I didnt think much of it and 5 days later a bolt broke and the compressor was hanging there. Basically now I'm trying to remove the compressor so I can get the other piece of the bolt out of the compressor to put a new one in
But I dont know how to remove the bolts from the hoses like are they just super torqued or what
I drained the gas from the red valve by the driver headlight and the valve just under the compressor
Old 08-11-2019, 12:36 PM
Got any pictures? There should be two bolts, front and rear, holding the compressor on. Are they both broken or is one broken and one missing?
The hose fittings have been there a long time and are probably just set up. Support the compressor, use a back-up and apply increasing torque to the fittings and they will eventually break free.
Old 08-11-2019, 06:31 PM
I actually managed to get them off with a bigger ratchet with the same 13mm and an adapter so I'm good on that I just have to get this piece of bolt out somehow
Old 08-12-2019, 11:38 AM
