Pike's Avatar
Location: Redmond WA Can anyone help me with my snorkle mod?
How do you remove those stupid bolts....
Ok, so I am trying to remove my intake manifold, and the lower bolts came out fine, but the upper ones don't have heads. They are just threaded rods that screw into the block. I got the nuts off the end, but the rods remain.
Would putting the nuts back on with loctite work? Assuming the loctite bond is stronger than the one to the block I could just screw them back off once the glue had dried.
My other option is to take the EGR filter off and the other stuff that is holding it in to the side, but that is not going to be fun.
Also, when I go to put the manifold back in, can I use normal bolts to facilitate the removal in the future. Any advice would be great! Thanks!
'77 924 - Metallic Blue - enlarged TB/ intake
'99 Specialized HardRock - Blue/Silver - Jett C Shocks - Cat Eye Velo computer
If it ain't broken, drive it until something is.
Have you spent quality time with your Engine Gnome lately?
Defend Your Joy
Old 03-25-2003, 05:04 PM
AFJuvat's Avatar
Those are studs - they are in with loctite RED. - don't even try to pull them unless they are damaged. - need heat (around 400 degrees) to get it to loosen itself up.
Replace the nuts with new ones, torque them down to spec - I use a little loctite BLUE - keeps them from shaking loose, but is removable with hand tools
No, you can't use bolts.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-25-2003, 05:11 PM
Pike's Avatar
ok, but....
I still can't get the manifold out with them in! Aside from a prybar that is. =) I got two of them out, one by itself and the other after a little work with no damage, but with the bottom mount where it is and the angle the little rods go into the block, it is still well stuck. =( Also, I did not see any red loctite. There was some red stuff that looked like disintegrated gasket on the bottom the the two rods that did come out....
Defend Your Joy
Old 03-25-2003, 05:18 PM
you are going to have to use the lock nut method. Screw one of the nuts back onto the stud about a third of the way down. Screw a second nut onto the stud, tight against the one you just put on. Use a wrench and turn the inner nut to take the stud out.
Rember left-loose right-tight.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 03-26-2003, 01:50 AM
Pike's Avatar
AFJ has convinced me not to take the others off, he says that I should not have gotten the first ones off, so I am going to try other things first. That is how I got the second one off by the way.
Defend Your Joy
Old 03-26-2003, 09:30 AM
