Oil Pump problems
Every time I start my car the oil pressure is at zero for about 1 minute sometimes it is even at zero for 2-3 minutes. Then it just all of a sudden goes up to its normal 4 bar. People tell me alot of different things regarding the problem, but I still don't know what is exactly wrong with it. Any suggestions
Old 03-08-2000, 03:18 PM
1.2gees's Avatar
Send a message via AIM to 1.2gees
What kind of car, what year? It is not possible to run the car at 0 oil pressure, it would hardly turnover. Sounds like your oil pressure sending unit, or something electrical. My 84 944 shows about 1 bar as soon as you hit the starter, before it even starts. Are you talking about the gauge or the pressure light?
Old 03-08-2000, 03:42 PM
lm6y's Avatar
Actually, you can run an engine without oil pressure. It won't last long though. I doubt if it is an oiling problem. If it ran for 2-3 minutes without oil pressure, you would notice something's wrong. It would knock or seize up. I agree that it's probably the sender or the gauge. But when in doubt, have it checked out. Paying a mechanic to check it out is a lot cheaper than paying him to build an engine.
Old 03-10-2000, 05:03 PM
