MotoRider42HC's Avatar
Angry Need Advice - My Helmet Hits The Roll Cage
My rally roll cage was built by one of the best FIA-spec cage builders in the business. However, after installing my seat, in the exact same position the builder used, my helmet hits the roll bar padding. And it doesn't lightly hit, it interferes; there is at least a 1/2" overlap. I have no idea what to do! Any suggestions you have are very much welcome! Please help!
https://www.youtube.com/watch?v=aiAwZjtD0C8
1987 Porsche 944 S
5.3L L33 LS Swap
Off-Road Rally Racing
https://www.youtube.com/PowerSports
Old 09-16-2019, 07:37 PM
racer's Avatar
Hmm.. while the work was ongoing, were you test fitting with your helmet on? It looks like there could have been room before the roll bar padding was installed. Is there any room to lower the seat (maybe bolt/weld to the floor vs on rails)? Remove any seat bottom padding? Look for a thinner seat that still meets rule requirements?
What does the builder recommend? Clearly "one of the best FIA-spec cage builders" has seen this before and might have some work around?
1987 924S
Past:
2000 Boxster 2.7, 1987 944
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 09-17-2019, 04:43 AM
Cajundaddy's Avatar
Changing the cage, lowering the seat, or changing the seat look like your only options. Choose one. To avoid contact in rally I would want at least 2" clearance.
2009 Cayman PDK
With a few tweaks
Old 09-17-2019, 05:26 AM
The cage builder is 10-hours away from me. But i am pretty sure he stuck a helmet on me and put me in the car, when i dropped it off. I sent him an email at the same time i posted this. He is used to having richey-rich customers, so i'm 50% gonna say his solution will be expensive and beyond my budget.
The seat is 1/4" to 1/2" off the floor. I'm going to try and add holes to the seat mounts tonight to drop it down.
The seat is an OMP First-R, it is the thinnest/nicest seat i could afford. I removed all the optional padding as soon as they arrived, lol, that **** was like 6" thick!
Thanks for your help!
1987 Porsche 944 S
5.3L L33 LS Swap
Old 09-17-2019, 05:51 AM
TWO INCHES !?!
I'm gonna have to tub the floor...
1987 Porsche 944 S
5.3L L33 LS Swap
Old 09-17-2019, 05:52 AM
In the Fires of Hell.....
kdjones2000's Avatar
Or tilt your seat back more to gain clearance...
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 09-17-2019, 06:39 AM
i tried that, my arms are too short. i wouldn't be able to reach the hydro, the dashboard switches, or throw 5th gear, lol.
also, the harness bar on the cage is too high, it barely meets belt angle specs with me sitting upright.
any way i look at it... seems like some expensive cutting and welding is in my future...
1987 Porsche 944 S
5.3L L33 LS Swap
Old 09-17-2019, 06:51 AM
curtisr
curtisr's Avatar
I would change the OMP-R for a Kirkey. These aluminum and SFI approved seats will put you right on the floor. They can be had for less than $200 at Summit, Jegs, etc.
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car)
1987 924s Garnet Red (with FIAMM air horns!)
1982 928 Silver (sold)
Old 09-18-2019, 04:45 AM
After not being happy with my seat sliders for many years in my 944 race car I finally just bolted the seat to the floor. with a quick disconnect steering wheel im super happy
Old 09-18-2019, 07:28 AM
is that FIA-approved?
my car must be FIA-spec
thanks!
1987 Porsche 944 S
5.3L L33 LS Swap
Old 09-18-2019, 08:14 AM
unfortunately, my seat is mounted to the floor. it is only hovering about 1/4" off the floor.
luckily, i do have a NRG quick disconnect short hub installed.
1987 Porsche 944 S
5.3L L33 LS Swap
Old 09-18-2019, 08:16 AM
With longer/taller steering wheel hub, you can tilt seat back more.
Is that bottom of seat itself? Or rails that's 1/4" off floor?
Please post photos of existing mounting. And cage. Thx
Old 09-20-2019, 11:48 PM
i decided to take the car to a shop near me that specializes in Rally cars.
i gave up trying to fix it myself.
i very much appreciate everyone's help, though.
^_^
1987 Porsche 944 S
5.3L L33 LS Swap
Old 09-21-2019, 06:29 AM
