LinkBack | Thread Tools | Rate Thread |
Relay board spade connectors
1984 944, 2.5L, manual transmission, UK right hand drive. http://944foot2thefloor.blogspot.com/ Last edited by massive; 09-18-2019 at 06:00 AM.. Reason: wrong terminology |
belmetric has double crimp connectors with the holding tab if you have the double crimp tool.
Yes I do, thanks, will check them out.
1984 944, 2.5L, manual transmission, UK right hand drive. http://944foot2thefloor.blogspot.com/ |
curtisr
I'm not sure what the problem is but, you can wire in (including removing the ceramic fuse holders and using the blades) one of these. Naturally, you can put 'em anywhere you want.
1977 924 Guards Red (parted and sold) 1987 924s Alpine White (sold) 1987 924s Kopenhagen Blue (my Lowencash tribute track car) 1987 924s Garnet Red 1982 928 Silver (sold) |
Thanks for the message, but this is about the relay board, not the fuse board. Thanks
You can look up any connector in PET and using the part number buy from Porsche or search and find alternative suppliers.
I think it’s #2 which is a generic 6.3 female blade connector and you’ll need one with a clip. It still could be a couple of numbers but N-017-494-3 looks promising and Sunset shows it as in-stock. ![]()
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. Last edited by 9FF; 09-18-2019 at 06:46 AM.. |
Take a close look at terminal. There should be angled metal tab that sticks out back (is that what they cal! Clip?). It bumps up against little plastic ledge in relay board case to hold it in.
First make sure metal tab sticks out far enough, about 2mm/30-degrees, see bottom of part #3 and #4 above. Gently pry it outwards if not. Next, inspect the relay board slot where terminal goes for location of ledge. Insert terminal oriented so metal tab latchs onto back side of ledge. In cases where plastic ledge has been destroyed by Neanderthals using screwdrivers to pry out terminal (rather than using proper extraction tool from front side), I rebuild it using 2-part epoxy. Use tiniest precision screwdriver, about 1mm, and dab a litte dot of epoxy on top of old worn-out ledge. Last edited by DannoXYZ; 09-18-2019 at 11:07 AM.. |
Thread Tools | |
Rate This Thread | |
